使用reactive父组件第二次传递给子组件的数据:方法中可以获取到最新数据
<template> <div> <div> <h1>子组件</h1> <child :infoObj='infoObj' ref="childRef"></child> </div> <button @click='updateHandler'>跟新值</button> <div> <h1>父页面</h1> <p>{{ infoObj }}</p> </div> </div></template><script setup lang="ts">import child from '@/components/child.vue'import { ref,reactive } from 'vue'let infoObj = reactive({ name:'张三', age:26})const childRef = ref()function updateHandler(){ infoObj.name = '李四' infoObj.age = 28 // 跟新值后,调用父组件的方法。 childRef.value.getData()}</script><template> <div> <h1> {{ props.infoObj }}</h1> </div></template><script setup lang="ts">let props = defineProps({ infoObj:Object,})function getData(){ console.log('infoObj', props.infoObj)}defineExpose({ getData})</script>
使用ref父组件第二次传递给子组件的数据:不能获取到最新的数据
<template> <div> <div> <h1>子组件</h1> <child :infoObj='infoObj' ref="childRef"></child> </div> <button @click='updateHandler'>跟新值</button> <div> <h1>父页面</h1> <p>{{ infoObj }}</p> </div> </div></template><script setup lang="ts">import child from '@/components/child.vue'import { ref } from 'vue'let infoObj = ref({ name:'张三', age:26})const childRef = ref()function updateHandler(){ infoObj.value = { name:'李四', age:28 } // 跟新值后,调用父组件的方法。看下getData是否可以获取到最新的值 childRef.value.getData()}</script><template> <div> <h1> {{ props.infoObj }}</h1> </div></template><script setup lang="ts">let props = defineProps({ infoObj:Object,})function getData(){ console.log('infoObj', props.infoObj)}defineExpose({ getData})</script>
办法1:将数据作为函数的参数进行传递
<template> <div> <div> <h1>子组件</h1> <child :infoObj='infoObj' ref="childRef"></child> </div> <button @click='updateHandler'>跟新值</button> <div> <h1>父页面</h1> <p>{{ infoObj }}</p> </div> </div></template><script setup lang="ts">import child from '@/components/child.vue'import { ref } from 'vue'let infoObj = ref({ name:'张三', age:26})const childRef = ref()function updateHandler(){ infoObj.value = { name:'李四', age:28 } // 将数据作为函数的参数进行传递 childRef.value.getData(infoObj.value)}</script><template> <div> <h1> {{ props.infoObj }}</h1> </div></template><script setup lang="ts">let props = defineProps({ infoObj:Object,})function getData(mess:any){ console.log('infoObj', props.infoObj) console.log('将数据作为函数的参数进行传递:mess', mess)}defineExpose({ getData})</script>
解决办法2:在调用方法时使用 nextTick
<template> <div> <div> <h1>子组件</h1> <child :infoObj='infoObj' ref="childRef"></child> </div> <div> <h1>父页面</h1> <p>{{ infoObj }}</p> </div> <button @click='updateHandler'>跟新值</button> </div></template><script setup lang="ts">import child from '@/components/child.vue'import { nextTick, ref } from 'vue'let infoObj = ref({ name:'张三', age:26})const childRef = ref()function updateHandler(){ infoObj.value = { name: '李四', age: 28 }; // 推荐在这里使用nextTick nextTick(() => { childRef.value.getData() })}</script><template> <div> <h1> {{ props.infoObj }}</h1> </div></template><script setup lang="ts">let props = defineProps({ infoObj:Object,})function getData(){ // 或者在这里使用nextTick。 console.log('getData 方法获取值', props.infoObj.name, props.infoObj.age)}defineExpose({ getData})</script>
结论
使用ref父组件第二次传递给子组件的数据(基本数据和引用数据):不能获取到最新的数据。
使用reactive和ref传递参数给子组件,为啥ref第二次子组件无法获取最新的数据?而reactive可以
在 Vue 3 中,reactive 和 ref 在传递给子组件时的行为有所不同。
这也说明了 reactive 和 ref 是有区别的(屁话)。
ref 和 reactive 的区别
1,ref可以试用于任何数据类型,而reactive只适用于对象类型。
2,在js模块ref获取值,设置值,需要点value, 在模板中使用不需要点value。 而reactive都不需要。
3,ref可以完全替换整个对象,不会失去响应式。
reactive不能直接替换整个对象(否则会失去响应式)。需要逐个修改属性或使用 Object.assign
4,返回值不同。ref返回一个包装对象。reactive返回一个Proxy 对象
ref完全替换 不会失去响应式
<template> <button type="button" @click="updateHandler">更改数据</button> <p>数据{{ objRef }}</p></template><script setup lang="ts">import { ref } from 'vue';const objRef = ref({ age: 1 })function updateHandler(){ //完全替换 不会失去响应式 objRef.value = { age: 100 } }</script>reactive不能直接替换整个对象(会失去响应式)
const objReactive = reactive({ a: 1 })// 错误方式(失去响应性)objReactive = { b: 2 }// 正确方式 或者逐个修改属性Object.assign(objReactive, { b: 2 })[错误]:ref解构不会失去响应式。reactive解构或展开会失去响应式。[这句话不正确]
ref和reactive解构都会失去响应式。都需要通过toRefs 或者toRef 来进行解决。
reactive 解构会失去响应式
<template> <button type="button" @click="updateHandler">更改数据</button> <p>数据{{ name }} {{ age}}</p></template><script setup lang="ts">import { reactive } from 'vue';const state = reactive({ name: '张三', age: 20 })// reactive解构会失去响应式let { name, age } = statefunction updateHandler(){ // 更新数据后,页面不会跟新 name = '王麻子' age = 1000}</script>
ref 解构会失去响应式
<template> <div> <p>Name: {{ name }}</p> <p>Age: {{ age }}</p> <button @click="changeName">Change Name</button> </div></template><script setup>import { ref } from 'vue'// 使用 ref 创建响应式对象const user = ref({ name: 'Alice', age: 25})// 解构 ref 对象 - 会失去响应式,视图不会跟新let { name, age } = user.valuefunction changeName() { name = 'Bob' // 直接修改解构出来的属性}</script>
toRefs()解构ref,解构后仍然保持响应式
<template> <div> <p>Name: {{ name }}</p> <p>Age: {{ age }}</p> <button @click="changeName">Change Name</button> </div></template><script setup>import { ref,toRefs } from 'vue'// 使用 ref 创建响应式对象const user = ref({ name: 'Alice', age: 25})// 通过toRefs解构不会失去响应式let { name, age } = toRefs(user.value) function changeName() { name.value = '大大再大' // 直接修改解构出来的属性}</script>
toRef()解构reactive,解构后仍然保持响应式
<template> <button type="button" @click="updateHandler">更改数据</button> <p>数据{{ name }} {{ age}}</p></template><script setup lang="ts">import { reactive, toRefs } from 'vue';const state = reactive({ name: '张三', age: 20 })// 通过toRefs解构不会失去响应式let { name, age } = toRefs(state) function updateHandler(){ // 更新数据后,页面不会跟新 name.value = '王麻子' age.value = 1000}</script>
toRefs()
官网:将一个响应式对象转换为一个普通对象。
这个普通对象的[每个属性]都是指向源对象[相应属性的] ref。
每个单独的 ref 都是使用 toRef() 创建的。
我的理解:
toRefs 可以把一个响应式对象转换为普通的对象。
该普通对象的每一个值都是ref。
由于变成了ref,所以我们使用每个属性的时候需要点value。
ref和reactive的使用场景
ref 适合于基本数据类型,reactive适合于对象类型。
ref 适合完全替换整个对象
我喜欢用ref定义基本数据类型和数组。对象使用reactive。
ref的本质
我理解的ref本质上是reactive的再封装。
使用reactive定义响应式数据时,若数据不是对象类型直接就返回了。
就不会进行后续的数据响应式处理了。
这也就是我只用reactive定义对象型响应式数据的原因 |
