【Azure App Service】在App Service for Windows上验证能占用的内存最大值
888974111
347
2025-2-7 03:15:52 | 显示全部楼层 |阅读模式
问题描述
在创建App Service服务的时候,根据定价层不同,内存使用的最大值也有不同。但在实际测试中,发现内存最大只能占用2GB左右,
而定价层中内存分配明明是大于2GB(比如B3定价层的内存为7GB), 这是一种什么情况呢?
在App Service中Kudu工具上,查看进程分配的内存大小:
问题解答
使用一段简短C#代码来进行验证,代码是一个循环,根据URL中输入的数字,循环创建多个100MB大小的对象.
var builder = WebApplication.CreateBuilder(args);// Add services to the container.var app = builder.Build();app.MapGet("/oom/{objs}", (string objs) =>{    int objunmbers = int.Parse(objs);    try    {        byte[][] largeArray = new byte[objunmbers][];        for (int i = 0; i < objunmbers; i++)        {            largeArray = new byte[1024 * 1024 * 100]; // 每个对象占用100MB        }        return "成功创建大数组对象: " + objs;    }    catch (OutOfMemoryException)    {        return "内存不足,无法创建大数组对象";    }});app.Run();
代码本地调试,可以看见应用占用内存直线上涨:
部署到Azure App Service后,同样通过Kudu站点Process信息,发现内存的占用的确只有2GB左右,但请求需要更多内存资源时,页面返回:内存不足,无法创建大数组对象
这是因为App Service for Windows默认使用32位操作系统,最大内存只能分配2GB。
当主动修改位64位后,App Service 内存就可以占用到定价层所允许的最大值!
如B3的定价层在Kudu中查看到w3wp.exe进程分配的内存达到了6GB
根据以上测验,当使用App Service内存没有达到预期的值,且应用异常日志出现OutOfMemory时,就需要检查Platform的设置是否位64bit。
参考资料
I see the message "Worker Process requested recycle due to 'Percent Memory' limit." How do I address this issue?
https://learn.microsoft.com/en-us/troubleshoot/azure/app-service/web-apps-performance-faqs#i-see-the-message-worker-process-requested-recycle-due-to-percent-memory-limit-how-do-i-address-this-issue
The maximum available amount of memory for a 32-bit process (even on a 64-bit operating system) is 2 GB. By default, the worker process is set to 32-bit in App Service (for compatibility with legacy web applications).
Consider switching to 64-bit processes so you can take advantage of the additional memory available in your Web Worker role. This triggers a web app restart, so schedule accordingly.
Also note that a 64-bit environment requires a Basic or Standard service plan. Free and Shared plans always run in a 32-bit environment.
GMT+8, 2025-3-10 15:50 , Processed in 0.753273 second(s), 30 queries .
