[Huawei]display interface GigabitEthernet 0/0/0
GigabitEthernet0/0/0 current state : UP
Line protocol current state : UP
Description:HUAWEI, AP Series, GigabitEthernet0/0/0 Interface
Switch Port, PVID : 1, TPID : 8100(Hex), The Maximum Frame Length is 1800
IP Sending Frames' Format is PKTFMT_ETHNT_2, Hardware address is 4cfa-ca65-2fe0
Last physical up time : 2005-07-27 11:02:51
Last physical down time : 2005-07-27 19:02:30 UTC+08:00
Current system time: 2005-07-27 11:14:24
Port Mode: COMMON COPPER
Speed : 10, Loopback: NONE
Duplex: FULL, Negotiation: ENABLE
Mdi : AUTO
Last 300 seconds input rate 104 bits/sec, 0 packets/sec
Last 300 seconds output rate 488 bits/sec, 0 packets/sec
Input peak rate 5536 bits/sec,Record time: 2005-07-27 11:03:56
Output peak rate 6520 bits/sec,Record time: 2005-07-27 11:03:56
Input: 25 packets, 9961 bytes
Unicast: 2, Multicast: 23
Broadcast: 0, Jumbo: 0
Discard: 0, Total Error: 0
CRC: 0, Giants: 0
Jabbers: 0, Throttles: 0
Runts: 0, Alignments: 0
Symbols: 0, Ignoreds: 0
Frames: 0
Output: 351 packets, 43560 bytes
Unicast: 0, Multicast: 348
Broadcast: 3, Jumbo: 0
Collisions: 0, ExcessiveCollisions: 0
Late Collisions: 0, Deferreds: 0
Buffers Purged: 0
Input bandwidth utilization threshold : 100.00%
Output bandwidth utilization threshold: 100.00%
Input bandwidth utilization : 0%
Output bandwidth utilization : 0.01%
[Huawei]display interface GigabitEthernet 0/0/1
GigabitEthernet0/0/1 current state : DOWN
Line protocol current state : DOWN
Description:HUAWEI, AP Series, GigabitEthernet0/0/1 Interface
Last physical up time : -
Current system time: 2005-07-27 11:13:59
Speed : 1000, Loopback: NONE
Mdi : AUTO
Last 300 seconds input rate 0 bits/sec, 0 packets/sec
Last 300 seconds output rate 0 bits/sec, 0 packets/sec
Input peak rate 0 bits/sec,Record time: -
Output peak rate 0 bits/sec,Record time: -
Input: 0 packets, 0 bytes
Unicast: 0, Multicast: 0
CRC: 0, Giants: 0
Frames: 0
Output: 0 packets, 0 bytes
Buffers Purged: 0
Output bandwidth utilization : 0% |
