查看: 32|回复: 0
华为AR路由器恢复出厂后的配置
查看: 32|回复: 0
华为AR路由器恢复出厂后的配置
查看: 32|回复: 0
354
qq5464642
354
2025-1-16 19:07:00 | 显示全部楼层 |阅读模式
Username:admin
Password:
Warning: The default password poses security risks.
The password needs to be changed. Change now? [Y/N]: y
Please enter old password:
Please enter new password:
Please confirm new password:
The password has been changed successfully.
<Huawei>
Warning: Auto-Config is working. Before configuring the device, stop Auto-Config. If you perform configurations when Auto-Config is running, the DHCP, routing, DNS, and VTY configurations will be lost. Do you want to stop Auto-Config? [y/n]:y
Info: Auto-Config has been stopped.
<Huawei>
<Huawei>
<Huawei>
<Huawei>
<Huawei>
<Huawei>
<Huawei>display cu
<Huawei>display current-configuration
[V200R009C00SPC600]
drop illegal-mac alarm
authentication-profile name default_authen_profile
authentication-profile name dot1x_authen_profile
authentication-profile name mac_authen_profile
authentication-profile name portal_authen_profile
authentication-profile name dot1xmac_authen_profile
authentication-profile name multi_authen_profile
dhcp enable
radius-server template default
pki realm default
ssl policy default_policy type server
pki-realm default
version tls1.0 tls1.1
ciphersuite rsa_aes_128_cbc_sha
ike proposal default
encryption-algorithm aes-256
dh group14
authentication-algorithm sha2-256
authentication-method pre-share
integrity-algorithm hmac-sha2-256
prf hmac-sha2-256
free-rule-template name default_free_rule
portal-access-profile name portal_access_profile
aaa
authentication-scheme default
authentication-scheme radius
   authentication-mode radius
authorization-scheme default
accounting-scheme default
local-aaa-user password policy administrator
   undo password alert original
domain default
domain default_admin
local-user admin password irreversible-cipher $1a$JL0A=-;[%~$/%y:HEmA.!_@Er8,pz{+Uj|~VpJFc2n;6w9QVA+R$
local-user admin privilege level 15
local-user admin service-type terminal http
firewall zone Local
interface GigabitEthernet0/0/0
interface GigabitEthernet0/0/1
interface GigabitEthernet0/0/2
interface GigabitEthernet0/0/3
interface GigabitEthernet0/0/4
interface GigabitEthernet0/0/5
interface GigabitEthernet0/0/6
interface GigabitEthernet0/0/7
interface GigabitEthernet0/0/8
interface GigabitEthernet0/0/9
ip address 192.168.1.1 255.255.255.0
dhcp select interface
interface GigabitEthernet0/0/10
interface GigabitEthernet0/0/11
interface GigabitEthernet0/0/12
interface GigabitEthernet0/0/13
description VirtualPort
ip address dhcp-alloc
interface Cellular0/0/0
interface Cellular0/0/1
interface NULL0
snmp-agent local-engineid 800007DB037817BE64060C
http secure-server ssl-policy default_policy
http server enable
http secure-server enable
http server permit interface GigabitEthernet0/0/9
fib regularly-refresh disable
user-interface con 0
authentication-mode aaa
user-interface vty 0
user privilege level 15
user-interface vty 1 4
wlan ac
traffic-profile name default
security-profile name default
security-profile name default-wds
   security wpa2 psk pass-phrase %^%#{@3HV47/O+SCD0-FQwQO9KAV+h&f[Pb/%D7fr:+V%^%# aes
ssid-profile name default
vap-profile name default
wds-profile name default
regulatory-domain-profile name default
air-scan-profile name default
rrm-profile name default
radio-2g-profile name default
radio-5g-profile name default
wids-spoof-profile name default
wids-profile name default
ap-system-profile name default
port-link-profile name default
wired-port-profile name default
ap-group name default
dot1x-access-profile name dot1x_access_profile
mac-access-profile name mac_access_profile
ops
autostart
secelog
return
<Huawei>
<Huawei>
<Huawei>save
<Huawei>save
Warning: The current configuration will be written to the device.
Are you sure to continue?[Y/N]:y
   It will take several minutes to save configuration file, please wait............
GMT+8, 2025-3-10 15:11 , Processed in 2.377917 second(s), 27 queries .
