目录
1.DB-GPT支持的功能
2.配置StarRocks数据库
3. ChatBI
- 数据准确性不够精准,如果用于生产需要做相关优化
- 查询可能会做大SQL查询,拖死web进程,无法响应
4. APP创建使用
dbgpt app install awel-flow-web-info-searchdbgpt app install awel-flow-example-chatdbgpt app install awel-flow-simple-streaming-chat安装可能因为网络问题报错,多执行几次就好了
5. 元数据库配置
LOCAL_DB_TYPE=mysql LOCAL_DB_USER= LOCAL_DB_PASSWORD= LOCAL_DB_HOST=127.0.0.1 LOCAL_DB_PORT=3306 LOCAL_DB_NAME=dbgpt6. API 调用探索
6.1 app
app chat api 模型替换
sk-xxxhttps://dashscope.aliyuncs.com/compatible-mode/v1llm model: qwen-long6.2 datasources
1.list datasources api error
During handling of the above exception, another exception occurred:Traceback (most recent call last): File "D:\software\PyCharm 2023.3.5\plugins\python\helpers-pro\pydevd_asyncio\pydevd_nest_asyncio.py", line 120, in run return loop.run_until_complete(task) File "D:\software\PyCharm 2023.3.5\plugins\python\helpers-pro\pydevd_asyncio\pydevd_nest_asyncio.py", line 211, in run_until_complete return f.result() File "C:\Users\jack\AppData\Local\Programs\Python\Python310\lib\asyncio\futures.py", line 201, in result raise self._exception.with_traceback(self._exception_tb) File "C:\Users\jack\AppData\Local\Programs\Python\Python310\lib\asyncio\tasks.py", line 232, in __step result = coro.send(None) File "C:\Users\jack\PycharmProjects\dbgpt-test\api\datasource.py", line 12, in list_ds res = await list_datasource(client=client) File "C:\Users\jack\PycharmProjects\dbgpt-test\.venv\lib\site-packages\dbgpt\client\datasource.py", line 120, in list_datasource raise ClientException(f"Failed to list datasource: {e}")dbgpt.client.client.ClientException: (Failed to list datasource: (E0003)Reason: {'success': False, 'err_code': 'E0003', 'err_msg': "1 validation errors:\n {'type': 'model_attributes_type', 'loc': ('response', 'data'), 'msg': 'Input should be a valid dictionary or object to extract fields from', 'input': [DatasourceServeResponse(id=1, db_type='mysql', db_name='dbgpt_test', db_path='', db_host='', db_port=3306, db_user='', db_pwd='', comment='')]}\n", 'data': None})Reason: None6.3 Knowledge
- 通过调用create_space接口失败但是创建了多个空间
Traceback (most recent call last): File "C:\Users\jack\PycharmProjects\dbgpt-test\api\knowledge.py", line 39, in <module> asyncio.run(delete()) File "C:\Users\jack\AppData\Local\Programs\Python\Python310\lib\asyncio\runners.py", line 44, in run return loop.run_until_complete(main) File "C:\Users\jack\AppData\Local\Programs\Python\Python310\lib\asyncio\base_events.py", line 649, in run_until_complete return future.result() File "C:\Users\jack\PycharmProjects\dbgpt-test\api\knowledge.py", line 24, in delete res = await delete_space(client=client, space_id='2') File "C:\Users\jack\PycharmProjects\dbgpt-test\.venv\lib\site-packages\dbgpt\client\knowledge.py", line 75, in delete_space raise ClientException(f"Failed to delete space: {e}")dbgpt.client.client.ClientException: (Failed to delete space: (E0003)Reason: {'success': False, 'err_code': 'E0003', 'err_msg': "1 validation errors:\n {'type': 'none_required', 'loc': ('response', 'data'), 'msg': 'Input should be None', 'input': SpaceServeResponse(id=2, name='test_space', vector_type='Chroma', desc='for client space', context=None, owner='dbgpt', sys_code=None, domain_type=None)}\n", 'data': None})Reason: Nonespace delete error invalid space name:test_space_abc
7. 问题总结
- 可能会生成大查询SQL,导致查询卡死,响应非常慢
- gbt任务会影响界面请求,gbt任务出问题会导致请求响应超时
- 目前Chat data 、DB等响应还不够准确,可能跟模型有关?
- 知识库创建的elsticsearch 卡片删除不掉
- 无法强制杀死正在运行中的对话任务
8. 贡献的PR
[1] https://github.com/eosphoros-ai/DB-GPT/pull/1794
[2] https://github.com/eosphoros-ai/DB-GPT/pull/1784
[3] https://github.com/eosphoros-ai/DB-GPT/pull/1789 |
