Easyexcel(5-自定义列宽)
Easyexcel(5-自定义列宽)
eUBiIdHz0
243
前天 12:58 | 显示全部楼层 |阅读模式
注解
@ColumnWidth
@Datapublic class WidthAndHeightData {        @ExcelProperty("字符串标题")    private String string;        @ExcelProperty("日期标题")    private Date date;    @ColumnWidth(50)    @ExcelProperty("数字标题")    private Double doubleData;}注解使用时表头长度无法做到动态调整,只能固定设置,每次调整表头长度时只能重新修改代码
注意:@ColumnWidth最大值只能为255,超过255*256长度时会报错
查看XSSFSheet源码
类方法
AbstractHeadColumnWidthStyleStrategy
public abstract class AbstractHeadColumnWidthStyleStrategy extends AbstractColumnWidthStyleStrategy {    @Override    protected void setColumnWidth(WriteSheetHolder writeSheetHolder, List<WriteCellData<?>> cellDataList, Cell cell, Head head,        Integer relativeRowIndex, Boolean isHead) {        // 判断是否满足 当前行索引不为空 && (当前是表头 || 当前行索引是首行)        // 如果不满足,则说明不是表头,不需要设置        boolean needSetWidth = relativeRowIndex != null && (isHead || relativeRowIndex == 0);        if (!needSetWidth) {            return;        }        Integer width = columnWidth(head, cell.getColumnIndex());        if (width != null) {            width = width * 256;            writeSheetHolder.getSheet().setColumnWidth(cell.getColumnIndex(), width);        }    }    protected abstract Integer columnWidth(Head head, Integer columnIndex);}通过继承AbstractHeadColumnWidthStyleStrategy类,实现columnWidth方法获取其对应列的宽度
SimpleColumnWidthStyleStrategy
源码查看
public class SimpleColumnWidthStyleStrategy extends AbstractHeadColumnWidthStyleStrategy {    private final Integer columnWidth;    public SimpleColumnWidthStyleStrategy(Integer columnWidth) {        this.columnWidth = columnWidth;    }    @Override    protected Integer columnWidth(Head head, Integer columnIndex) {        return columnWidth;    }}基本使用
通过registerWriteHandler设置策略方法调整每列的固定宽度
@Datapublic class User {    @ExcelProperty(value = "用户Id")    private Integer userId;    @ExcelProperty(value = "姓名")    private String name;    @ExcelProperty(value = "手机")    private String phone;    @ExcelProperty(value = "邮箱")    private String email;    @ExcelProperty(value = "创建时间")    private Date createTime;}@GetMapping("/download2")public void download2(HttpServletResponse response) {    try {        response.setContentType("application/vnd.ms-excel");        response.setCharacterEncoding("utf-8");        // 这里URLEncoder.encode可以防止中文乱码 当然和easyexcel没有关系        String fileName = URLEncoder.encode("测试", "UTF-8").replaceAll("\\+", "%20");        response.setHeader("Content-disposition", "attachment;filename=" + fileName + ".xls");        User user = new User();        user.setUserId(123);        user.setName("asplplplplpplplplplpl");        user.setPhone("15245413");        user.setEmail("54565454@qq.com");        user.setCreateTime(new Date());        EasyExcel.write(response.getOutputStream(), User.class)                .sheet("模板")                .registerWriteHandler(new SimpleColumnWidthStyleStrategy(20))                .doWrite(Arrays.asList(user));    } catch (Exception e) {        e.printStackTrace();    }}
LongestMatchColumnWidthStyleStrategy
源码查看
public class LongestMatchColumnWidthStyleStrategy extends AbstractColumnWidthStyleStrategy {    private static final int MAX_COLUMN_WIDTH = 255;    private final Map<Integer, Map<Integer, Integer>> cache = MapUtils.newHashMapWithExpectedSize(8);    @Override    protected void setColumnWidth(WriteSheetHolder writeSheetHolder, List<WriteCellData<?>> cellDataList, Cell cell,        Head head,        Integer relativeRowIndex, Boolean isHead) {        // 判断 是否为表头 || 导出内容是否为空        boolean needSetWidth = isHead || !CollectionUtils.isEmpty(cellDataList);        if (!needSetWidth) {            return;        }        Map<Integer, Integer> maxColumnWidthMap = cache.computeIfAbsent(writeSheetHolder.getSheetNo(), key -> new HashMap<>(16));        Integer columnWidth = dataLength(cellDataList, cell, isHead);        if (columnWidth < 0) {            return;        }        // 超过最大值255时则设置为255        if (columnWidth > MAX_COLUMN_WIDTH) {            columnWidth = MAX_COLUMN_WIDTH;        }        // 比较该列的宽度,如果比原来的宽度大,则重新设置        Integer maxColumnWidth = maxColumnWidthMap.get(cell.getColumnIndex());        if (maxColumnWidth == null || columnWidth > maxColumnWidth) {            maxColumnWidthMap.put(cell.getColumnIndex(), columnWidth);            writeSheetHolder.getSheet().setColumnWidth(cell.getColumnIndex(), columnWidth * 256);        }    }    private Integer dataLength(List<WriteCellData<?>> cellDataList, Cell cell, Boolean isHead) {        // 如果是表头,则返回表头的宽度        if (isHead) {            return cell.getStringCellValue().getBytes().length;        }        // 如果是单元格内容,则根据类型返回其内容的宽度        WriteCellData<?> cellData = cellDataList.get(0);        CellDataTypeEnum type = cellData.getType();        if (type == null) {            return -1;        }        switch (type) {            case STRING:                return cellData.getStringValue().getBytes().length;            case BOOLEAN:                return cellData.getBooleanValue().toString().getBytes().length;            case NUMBER:                return cellData.getNumberValue().toString().getBytes().length;            default:                return -1;        }    }}LongestMatchColumnWidthStyleStrategy是一个列宽自适应策略。当我们在写入Excel数据时,如果希望根据数据的实际长度来自适应调整列宽,就可以使用这个策略。它会遍历指定列的所有数据(包括表头),找出最长的数据,然后根据这个最长数据的长度来设定该列的宽度,确保数据在单元格内不会被截断。
根据官网介绍:这个目前不是很好用,比如有数字就会导致换行。而且长度也不是刚好和实际长度一致。 所以需要精确到刚好列宽的慎用。
基本使用
@GetMapping("/download1")public void download1(HttpServletResponse response) {    try {        response.setContentType("application/vnd.ms-excel");        response.setCharacterEncoding("utf-8");        // 这里URLEncoder.encode可以防止中文乱码 当然和easyexcel没有关系        String fileName = URLEncoder.encode("测试", "UTF-8").replaceAll("\\+", "%20");        response.setHeader("Content-disposition", "attachment;filename=" + fileName + ".xls");        User user = new User();        user.setUserId(123);        user.setName("asplplplplpplplplplpl");        user.setPhone("15245413");        user.setEmail("54565454@qq.com");        user.setCreateTime(new Date());        EasyExcel.write(response.getOutputStream(), User.class)                .sheet("模板")                .registerWriteHandler(new LongestMatchColumnWidthStyleStrategy())                .doWrite(Arrays.asList(user));    } catch (Exception e) {        e.printStackTrace();    }}
表头宽度工具类
仿照LongestMatchColumnWidthStyleStrategy源码自定义工具类
使用构造器传参的方式,用户可以自定义通过表头或者单元格内容长度来设置列宽,通过修改常数值和比例可以自己设置想调整的列宽
/** * 表头宽度根据表头或数据内容自适应 */public class CustomWidthStyleStrategy extends AbstractColumnWidthStyleStrategy {    /**     * 1-根据表头宽度,2-根据单元格内容     */    private Integer type;    private Map<Integer, Map<Integer, Integer>> cache = new HashMap<>();    public CustomWidthStyleStrategy(Integer type) {        this.type = type;    }    /**     * 设置列宽     *     * @param writeSheetHolder 写入Sheet的持有者     * @param cellDataList 当前列的单元格数据列表     * @param cell 当前单元格     * @param head 表头     * @param relativeRowIndex 当前行的相对索引     * @param isHead 是否为表头     */    @Override    protected void setColumnWidth(WriteSheetHolder writeSheetHolder, List<WriteCellData<?>> cellDataList, Cell cell, Head head, Integer relativeRowIndex, Boolean isHead) {        if (type == 1) {            if (isHead) {                int columnWidth = cell.getStringCellValue().length();                columnWidth = Math.max(columnWidth * 2, 20);                if (columnWidth > 255) {                    columnWidth = 255;                }                writeSheetHolder.getSheet().setColumnWidth(cell.getColumnIndex(), columnWidth * 256);            }            return;        }        //不把标头计算在内        boolean needSetWidth = isHead || !CollectionUtils.isEmpty(cellDataList);        if (needSetWidth) {            Map<Integer, Integer> maxColumnWidthMap = cache.get(writeSheetHolder.getSheetNo());            if (maxColumnWidthMap == null) {                maxColumnWidthMap = new HashMap<>();                cache.put(writeSheetHolder.getSheetNo(), maxColumnWidthMap);            }            Integer columnWidth = this.dataLength(cellDataList, cell, isHead);            if (columnWidth >= 0) {                if (columnWidth > 255) {                    columnWidth = 255;                }                Integer maxColumnWidth = maxColumnWidthMap.get(cell.getColumnIndex());                if (maxColumnWidth == null || columnWidth > maxColumnWidth) {                    maxColumnWidthMap.put(cell.getColumnIndex(), columnWidth);                    writeSheetHolder.getSheet().setColumnWidth(cell.getColumnIndex(), columnWidth * 256);                }            }        }    }    /**     * 数据长度     *     * @param cellDataList     * @param cell     * @param isHead     * @return     */    private Integer dataLength(List<WriteCellData<?>> cellDataList, Cell cell, Boolean isHead) {        //头直接返回原始长度        if (isHead) {            return cell.getStringCellValue().getBytes().length;        } else {            //不是头的话  看是什么类型  用数字加就可以了            WriteCellData cellData = cellDataList.get(0);            CellDataTypeEnum type = cellData.getType();            if (type == null) {                return -1;            } else {                switch (type) {                    case STRING:                        return cellData.getStringValue().getBytes().length + 1;                    case BOOLEAN:                        return cellData.getBooleanValue().toString().getBytes().length;                    case NUMBER:                        return cellData.getNumberValue().toString().getBytes().length * 2;                    case DATE:                        return cellData.getDateValue().toString().length() + 1;                    default:                        return -1;                }            }        }    }}@GetMapping("/download3")public void download3(HttpServletResponse response) {    try {        response.setContentType("application/vnd.ms-excel");        response.setCharacterEncoding("utf-8");        // 这里URLEncoder.encode可以防止中文乱码 当然和easyexcel没有关系        String fileName = URLEncoder.encode("测试", "UTF-8").replaceAll("\\+", "%20");        response.setHeader("Content-disposition", "attachment;filename=" + fileName + ".xls");        User user = new User();        user.setUserId(123);        user.setName("asplplplplpplplplplpl");        user.setPhone("15245413");        user.setEmail("54565454@qq.com");        user.setCreateTime(new Date());        EasyExcel.write(response.getOutputStream(), User.class)                .sheet("模板")                .registerWriteHandler(new CustomWidthStyleStrategy(1))                .doWrite(Arrays.asList(user));    } catch (Exception e) {        e.printStackTrace();    }}@GetMapping("/download4")public void download4(HttpServletResponse response) {    try {        response.setContentType("application/vnd.ms-excel");        response.setCharacterEncoding("utf-8");        // 这里URLEncoder.encode可以防止中文乱码 当然和easyexcel没有关系        String fileName = URLEncoder.encode("测试", "UTF-8").replaceAll("\\+", "%20");        response.setHeader("Content-disposition", "attachment;filename=" + fileName + ".xls");        User user = new User();        user.setUserId(123);        user.setName("asplplplplpplplplplpl");        user.setPhone("15245413");        user.setEmail("54565454@qq.com");        user.setCreateTime(new Date());        EasyExcel.write(response.getOutputStream(), User.class)                .sheet("模板")                .registerWriteHandler(new CustomWidthStyleStrategy(2))                .doWrite(Arrays.asList(user));    } catch (Exception e) {        e.printStackTrace();    }}运行结果
  • 使用表头设置的列宽
  • 使用单元格内容设置的列宽
GMT+8, 2025-3-10 19:29 , Processed in 2.529052 second(s), 29 queries .
