使用cy7c68013调试mt9v011 ov7670 mt9v034 摄像头测试 icamera视频采集调试
QwcXuu7
207
2025-3-2 12:51:31 | 显示全部楼层 |阅读模式
使用cy7c68013调试mt9v011  ov7670 摄像头测试  icamera视频采集调试
 采集底板选用cp601d,原理图参考icamera设计,使用cy7c68013a芯片设计,固件刷icamera-106.iic(106后的版本均兼容)
注意好管脚顺序
OE接地使能,
复位管脚接高电平,处于正常工作
编写配置文件
iic配置地址为0xba
0x1a, 0x00, 0xBA, // 42 0x5A // sensor slave id
0x1a, 0x01, 0x00,        // pwdn low
0x1a, 0x02, 0x01, // wordwide <1:8 bit, else:16 bit>
0x1a, 0x03, 0x01,        // register address length 2byte
0x1a, 0x04, 0x02,        // register value length   1byte
//0x1a, 0x05, 0x01,        // reset pin(PC2)
0x1a, 0x06, 0x01,        // IFCLK polarity
0x1a, 0x0D, 0x02,        // IFCLK 24
0x22,0x09,0x005f,
0x22,0x35,0x0313,
0x22,0x01,0x000b,
0x22,0x02,0x0012,
0x22,0x05,0x0083,
0x22,0x06,0x001c,
0x22,0x20,0x1000,
参考芯片手册调整好配置文件,即可出图
视频显示
调整rgb各个通道增益和曝光,可以让图像更柔和,亮度更合适。
这就是所谓的白平衡和曝光调节,可以实时看效果
 调试ov7670
线序定义
安装效果如下,两类摄像头设计的时候线序有所不同,所以装不同位置区分
寄存器配置
0x12, 0x12, 0x80
0x12, 0x11, 0x01
0x12, 0x3a, 0x04
0x12, 0x12, 0x01
0x12, 0x17, 0x13
0x12, 0x18, 0x01
0x12, 0x32, 0xb6
0x12, 0x19, 0x02
0x12, 0x1a, 0x7a
0x12, 0x03, 0x0a
0x12, 0x0c, 0x00
0x12, 0x3e, 0x00
0x12, 0x70, 0x3a
0x12, 0x71, 0x35
0x12, 0x72, 0x11
0x12, 0x73, 0xf0
0x12, 0xa2, 0x02
0x12, 0x7a, 0x29
0x12, 0x7b, 0x04
0x12, 0x7c, 0x19
0x12, 0x7d, 0x30
0x12, 0x7e, 0x56
0x12, 0x7f, 0x65
0x12, 0x80, 0x72
0x12, 0x81, 0x7d
0x12, 0x82, 0x86
0x12, 0x83, 0x8c
0x12, 0x84, 0x95
0x12, 0x85, 0xa2
0x12, 0x86, 0xac
0x12, 0x87, 0xbe
0x12, 0x88, 0xcf
0x12, 0x89, 0xe1
0x12, 0x13, 0xe0
0x12, 0x00, 0x00
0x12, 0x10, 0x00
0x12, 0x0d, 0x40
0x12, 0x14, 0x38
0x12, 0xa5, 0x05
0x12, 0xab, 0x07
0x12, 0x24, 0x95
0x12, 0x25, 0x33
0x12, 0x26, 0xe3
0x12, 0x9f, 0x72
0x12, 0xa0, 0x62
0x12, 0xa1, 0x0b
0x12, 0xa6, 0xe5
0x12, 0xa7, 0xe5
0x12, 0xa8, 0xf0
0x12, 0xa9, 0x90
0x12, 0xaa, 0x94
0x12, 0x13, 0xe5
0x12, 0x0e, 0x61
0x12, 0x0f, 0x4b
0x12, 0x16, 0x02
0x12, 0x21, 0x02
0x12, 0x22, 0x91
0x12, 0x29, 0x07
0x12, 0x33, 0x0b
0x12, 0x35, 0x33
0x12, 0x37, 0x1c
0x12, 0x38, 0x71
0x12, 0x39, 0x3d
0x12, 0x3c, 0x78
0x12, 0x4d, 0x40
0x12, 0x4e, 0x20
0x12, 0x69, 0x55
0x12, 0x6b, 0x4a
0x12, 0x74, 0x19
0x12, 0x8d, 0x4f
0x12, 0x8e, 0x00
0x12, 0x8f, 0x00
0x12, 0x90, 0x00
0x12, 0x91, 0x00
0x12, 0x96, 0x00
0x12, 0x9a, 0x80
0x12, 0xb0, 0x8c
0x12, 0xb1, 0x0c
0x12, 0xb2, 0x0e
0x12, 0xb3, 0x82
0x12, 0xb8, 0x0a
0x12, 0x43, 0x14
0x12, 0x44, 0xf0
0x12, 0x45, 0x34
0x12, 0x46, 0x58
0x12, 0x47, 0x28
0x12, 0x48, 0x3a
0x12, 0x59, 0x88
0x12, 0x5a, 0x88
0x12, 0x5b, 0x44
0x12, 0x5c, 0x67
0x12, 0x5d, 0x49
0x12, 0x5e, 0x0e
0x12, 0x6c, 0x0a
0x12, 0x6d, 0x55
0x12, 0x6e, 0x11
0x12, 0x6f, 0x9f
0x12, 0x6a, 0x40
0x12, 0x01, 0x40
0x12, 0x02, 0x40
0x12, 0x13, 0xe7
0x12, 0x4f, 0x78
0x12, 0x50, 0x73
0x12, 0x51, 0x05
0x12, 0x52, 0x17
0x12, 0x53, 0x69
0x12, 0x54, 0x7f
0x12, 0x58, 0x9e
0x12, 0x41, 0x08
0x12, 0x3f, 0x00
0x12, 0x75, 0x05
0x12, 0x76, 0x60
0x12, 0x4c, 0x00
0x12, 0x77, 0x02
0x12, 0x3d, 0x08
0x12, 0x4b, 0x09
0x12, 0xc9, 0x60
0x12, 0x41, 0x38
0x12, 0x56, 0x40
0x12, 0x62, 0x00
0x12, 0x63, 0x00
0x12, 0x64, 0x04
0x12, 0x65, 0x00
0x12, 0x66, 0x01
0x12, 0x34, 0x11
0x12, 0x3b, 0xba
0x12, 0xa4, 0x88
0x12, 0x96, 0x00
0x12, 0x97, 0x30
0x12, 0x98, 0x20
0x12, 0x99, 0x20
0x12, 0x9a, 0x84
0x12, 0x9b, 0x29
0x12, 0x9c, 0x03
0x12, 0x9d, 0x99
0x12, 0x9e, 0x7f
0x12, 0x78, 0x04
0x12, 0x79, 0x01
0x12, 0xc8, 0xf0
0x12, 0x79, 0x0f
0x12, 0xc8, 0x20
0x12, 0x79, 0x10
0x12, 0xc8, 0x7e
0x12, 0xc8, 0x20
0x12, 0x79, 0x09
0x12, 0xc8, 0x80
0x12, 0x79, 0x02
0x12, 0xc8, 0xc0
0x12, 0x79, 0x03
0x12, 0xc8, 0x40
0x12, 0x79, 0x05
0x12, 0xc8, 0x30
0x12, 0x79, 0x26
拍照效果
启用ov7670的内部自动增益,自动曝光,自动白平衡,采集效果显著比人为手工初步简单配置的效果会好,
配置测试mt9v034(管脚顺序与ov7670兼容)
没有镜头,仍然不影响测试
配置寄存器
mt9v034_VGA_RAW
mode=Video
iface=Cypress
format=Raw
Type=RGGB
imagesize=640x480
afmode=CYPRESS_IIC
afsubmode=0
simmian
fPll=0
nPClkInvert=0
nRemoveFirst=0
n2Cut= 0
nSlaveID=0
nSensorCtrl=0
nBits=0
nIICSpeed=0
[SENSOR]
; VENDOR 0x1a for configuration
; VENDOR 0x1e for vcm
; VENDOR 0x12 for 1 byte  address and 1 byte  data
; VENDOR 0x22 for 1 byte  address and 2 bytes data
; VENDOR 0x32 for 2 bytes address and 1 byte  data
; VENDOR 0x42 for 2 bytes address and 2 bytes data
; VENDOR 0x52 for 1 byte  address and sequence datas
; VENDOR 0x62 for 2 bytes address and sequence datas
0x1a, 0x00, 0x90,        // 42 0x5A // sensor slave id
//0x1a, 0x05, 0x01        // reset pin(PC2)
0x22,0x03,0x1e0,
0x22,0x04,0x280,
0x1a, 0x0e, 0x01,        // external clock
0x1a, 0x0f, 0x00,        // sync
配置完成后,直接操控icamera上位机采集视频图像
可以观测到,帧率达到62fps,图像正常,通过直方图看到摄像头的噪声非常低。
此致所有摄像头测试已经完毕
GMT+8, 2025-3-11 06:16 , Processed in 0.836965 second(s), 29 queries .
