Java 加密和解密
Java 加密和解密
CpOLgnB0y
223
2025-2-22 22:39:47 | 显示全部楼层 |阅读模式
在 Java 中,加密和解密通常通过 Java Cryptography Architecture (JCA)Java Cryptography Extension (JCE) 实现。以下是常见的加密和解密操作示例,包括对称加密(如 AES)和非对称加密(如 RSA)。
<hr>一、对称加密(AES 示例)
对称加密使用相同的密钥进行加密和解密。
import javax.crypto.Cipher;import javax.crypto.KeyGenerator;import javax.crypto.SecretKey;import java.util.Base64;public class AESExample {    public static void main(String[] args) throws Exception {        // 生成密钥        KeyGenerator keyGen = KeyGenerator.getInstance("AES");        keyGen.init(128); // 128位密钥        SecretKey secretKey = keyGen.generateKey();        // 加密        String originalText = "Hello, World!";        Cipher cipher = Cipher.getInstance("AES");        cipher.init(Cipher.ENCRYPT_MODE, secretKey);        byte[] encryptedBytes = cipher.doFinal(originalText.getBytes());        String encryptedText = Base64.getEncoder().encodeToString(encryptedBytes);        System.out.println("加密后: " + encryptedText);        // 解密        cipher.init(Cipher.DECRYPT_MODE, secretKey);        byte[] decryptedBytes = cipher.doFinal(Base64.getDecoder().decode(encryptedText));        String decryptedText = new String(decryptedBytes);        System.out.println("解密后: " + decryptedText);    }}<hr>二、非对称加密(RSA 示例)
非对称加密使用公钥加密,私钥解密。
import javax.crypto.Cipher;import java.security.KeyPair;import java.security.KeyPairGenerator;import java.util.Base64;public class RSAExample {    public static void main(String[] args) throws Exception {        // 生成密钥对        KeyPairGenerator keyPairGen = KeyPairGenerator.getInstance("RSA");        keyPairGen.initialize(2048); // 2048位密钥        KeyPair keyPair = keyPairGen.generateKeyPair();        // 加密        String originalText = "Hello, World!";        Cipher cipher = Cipher.getInstance("RSA");        cipher.init(Cipher.ENCRYPT_MODE, keyPair.getPublic());        byte[] encryptedBytes = cipher.doFinal(originalText.getBytes());        String encryptedText = Base64.getEncoder().encodeToString(encryptedBytes);        System.out.println("加密后: " + encryptedText);        // 解密        cipher.init(Cipher.DECRYPT_MODE, keyPair.getPrivate());        byte[] decryptedBytes = cipher.doFinal(Base64.getDecoder().decode(encryptedText));        String decryptedText = new String(decryptedBytes);        System.out.println("解密后: " + decryptedText);    }}<hr>三、哈希算法(SHA-256 示例)
哈希算法用于生成不可逆的摘要信息。
import java.security.MessageDigest;import java.util.HexFormat;public class SHA256Example {    public static void main(String[] args) throws Exception {        String originalText = "Hello, World!";        MessageDigest digest = MessageDigest.getInstance("SHA-256");        byte[] hashBytes = digest.digest(originalText.getBytes());        String hashText = HexFormat.of().formatHex(hashBytes);        System.out.println("SHA-256 哈希值: " + hashText);    }}<hr>四、注意事项
  • 密钥管理:密钥的安全性至关重要,建议使用安全的密钥存储和管理方式(如 KeyStore)。
  • 算法选择:根据需求选择合适的加密算法(如 AES 用于对称加密,RSA 用于非对称加密)。
  • 填充模式:加密时需指定填充模式(如 AES/CBC/PKCS5Padding),确保与解密方一致。
  • 异常处理:加密解密操作可能抛出异常,需进行适当的异常处理。
<hr>五、常用加密算法
类型算法描述对称加密AES高级加密标准,速度快对称加密DES/3DES数据加密标准,较旧非对称加密RSA基于大数分解,安全性高非对称加密ECC椭圆曲线加密,密钥短效率高哈希算法SHA-256生成 256 位哈希值哈希算法MD5生成 128 位哈希值,已不安全<hr>通过以上示例和说明,您可以在 Java 中实现基本的加密和解密操作。如果需要更复杂的功能(如数字签名、证书管理等),可以进一步研究 JCA 和 JCE 的高级特性。 😊
GMT+8, 2025-3-12 01:24 , Processed in 1.805797 second(s), 26 queries .
