通过docker容器查看run命令
通过docker容器查看run命令
FKpV8AHc0Oo
226
2025-2-21 20:11:38 | 显示全部楼层 |阅读模式
模版文件来自https://gist.githubusercontent.com/efrecon/8ce9c75d518b6eb863f667442d7bc679/raw/run.tpl
假设容器名是 mysql, 命令后面可以跟容器名或者容器 id。命令如下:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
docker inspect --format 'docker run \
  --name {{printf "%q" .Name}} \
    {{- with .HostConfig}}
        {{- if .Privileged}}
  --privileged \
        {{- end}}
        {{- if .AutoRemove}}
  --rm \
        {{- end}}
        {{- if .Runtime}}
  --runtime {{printf "%q" .Runtime}} \
        {{- end}}
        {{- range $b := .Binds}}
  --volume {{printf "%q" $b}} \
        {{- end}}
        {{- range $v := .VolumesFrom}}
  --volumes-from {{printf "%q" $v}} \
        {{- end}}
        {{- range $l := .Links}}
  --link {{printf "%q" $l}} \
        {{- end}}
        {{- if index . "Mounts"}}
            {{- range $m := .Mounts}}
  --mount type={{.Type}}
                {{- if $s := index $m "Source"}},source={{$s}}{{- end}}
                {{- if $t := index $m "Target"}},destination={{$t}}{{- end}}
                {{- if index $m "ReadOnly"}},readonly{{- end}}
                {{- if $vo := index $m "VolumeOptions"}}
                    {{- range $i, $v := $vo.Labels}}
                        {{- printf ",volume-label=%s=%s" $i $v}}
                    {{- end}}
                    {{- if $dc := index $vo "DriverConfig" }}
                        {{- if $n := index $dc "Name" }}
                            {{- printf ",volume-driver=%s" $n}}
                        {{- end}}
                        {{- range $i, $v := $dc.Options}}
                            {{- printf ",volume-opt=%s=%s" $i $v}}
                        {{- end}}
                    {{- end}}
                {{- end}}
                {{- if $bo := index $m "BindOptions"}}
                    {{- if $p := index $bo "Propagation" }}
                        {{- printf ",bind-propagation=%s" $p}}
                    {{- end}}
                {{- end}} \
            {{- end}}
        {{- end}}
        {{- if .PublishAllPorts}}
  --publish-all \
        {{- end}}
        {{- if .UTSMode}}
  --uts {{printf "%q" .UTSMode}} \
        {{- end}}
        {{- with .LogConfig}}
  --log-driver {{printf "%q" .Type}} \
            {{- range $o, $v := .Config}}
  --log-opt {{$o}}={{printf "%q" $v}} \
            {{- end}}
        {{- end}}
        {{- with .RestartPolicy}}
  --restart "{{.Name -}}
            {{- if eq .Name "on-failure"}}:{{.MaximumRetryCount}}
            {{- end}}" \
        {{- end}}
        {{- range $e := .ExtraHosts}}
  --add-host {{printf "%q" $e}} \
        {{- end}}
        {{- range $v := .CapAdd}}
  --cap-add {{printf "%q" $v}} \
        {{- end}}
        {{- range $v := .CapDrop}}
  --cap-drop {{printf "%q" $v}} \
        {{- end}}
        {{- range $d := .Devices}}
  --device {{printf "%q" (index $d).PathOnHost}}:{{printf "%q" (index $d).PathInContainer}}:{{(index $d).CgroupPermissions}} \
        {{- end}}
    {{- end}}
    {{- with .NetworkSettings -}}
        {{- range $p, $conf := .Ports}}
            {{- with $conf}}
  --publish "
                {{- if $h := (index $conf 0).HostIp}}{{$h}}:
                {{- end}}
                {{- (index $conf 0).HostPort}}:{{$p}}" \
            {{- end}}
        {{- end}}
        {{- range $n, $conf := .Networks}}
            {{- with $conf}}
  --network {{printf "%q" $n}} \
                {{- range $a := $conf.Aliases}}
  --network-alias {{printf "%q" $a}} \
                {{- end}}
            {{- end}}
        {{- end}}
    {{- end}}
    {{- with .Config}}
        {{- if .Hostname}}
  --hostname {{printf "%q" .Hostname}} \
        {{- end}}
        {{- if .Domainname}}
  --domainname {{printf "%q" .Domainname}} \
        {{- end}}
        {{- if index . "ExposedPorts"}}
        {{- range $p, $conf := .ExposedPorts}}
  --expose {{printf "%q" $p}} \
        {{- end}}
        {{- end}}
        {{- if .User}}
  --user {{printf "%q" .User}} \
        {{- end}}
        {{- range $e := .Env}}
  --env {{printf "%q" $e}} \
        {{- end}}
        {{- range $l, $v := .Labels}}
  --label {{printf "%q" $l}}={{printf "%q" $v}} \
        {{- end}}
    {{- if not (or .AttachStdin  (or .AttachStdout .AttachStderr))}}
  --detach \
    {{- end}}
    {{- if .AttachStdin}}
  --attach stdin \
    {{- end}}
    {{- if .AttachStdout}}
  --attach stdout \
    {{- end}}
    {{- if .AttachStderr}}
  --attach stderr \
    {{- end}}
    {{- if .Tty}}
  --tty \
    {{- end}}
    {{- if .OpenStdin}}
  --interactive \
    {{- end}}
    {{- if .Entrypoint}}
{{- /* Since the entry point cannot be overridden from the command line with an array of size over 1,
       we are fine assuming the default value in such a case. */ -}}
        {{- if eq (len .Entrypoint) 1 }}
  --entrypoint "
            {{- range $i, $v := .Entrypoint}}
                {{- if $i}} {{end}}
                {{- $v}}
            {{- end}}" \
        {{- end}}
    {{- end}}
  {{printf "%q" .Image}} \
  {{range .Cmd}}{{printf "%q " .}}{{- end}}
{{- end}}' \
mysql
得到的结果和原始的不一样,但是大差不差了。
1
2
3
4
docker run --rm -v /var/run/docker.sock:/var/run/docker.sock:ro assaflavie/runlike mysql
# 或者用这个
docker run --rm -v /var/run/docker.sock:/var/run/docker.sock:ro cucker/get_command_4_run_container mysql
runlike 的结果也是近似的
GMT+8, 2025-3-11 01:20 , Processed in 0.676764 second(s), 26 queries .
