在Kubernetes中部署zookeeper集群
CTwZVfsAII
226
2025-2-21 20:07:01 | 显示全部楼层 |阅读模式
部署遇到的问题
挂载目录没有写入权限
修改容器启动命令,查看到用户 id 是 1001
官方也有说明
解决方法 1: 使用 initcontainer 授权
1
2
3
4
5
6
7
8
initContainers:
- name: init
  image: busybox:1.28
  command: ['sh', '-c', "chown -R 1001:1001 /bitnami/"]
  volumeMounts:
    - name: data
      mountPath: /bitnami/zookeeper
解决方法 2: 增加安全上下文,使用 root 用户
这么做会降低容器的安全性,不推荐!
1
2
3
securityContext:
  runAsUser: 0
  runAsGroup: 0
最终的 yaml 文件
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
apiVersion: v1
kind: Service
metadata:
  labels:
    app: zookeeper
spec:
  ports:
    - name: tcp-client
      protocol: TCP
      port: 2181
      targetPort: 2181
    - name: tcp-follower
      port: 2888
      targetPort: 2888
    - name: tcp-election
      port: 3888
      targetPort: 3888
  selector:
    app: zookeeper
  clusterIP: None
  type: ClusterIP
apiVersion: apps/v1
kind: StatefulSet
metadata:
  labels:
    app: zookeeper
spec:
  replicas: 3
  selector:
    matchLabels:
      app: zookeeper
  serviceName: zk-hs
  template:
    metadata:
      labels:
        app: zookeeper
    spec:
      # 使用 initContainers 解决挂载目录没有权限写入问题
      initContainers:
      - name: init
        image: busybox:1.28
        volumeMounts:
          - name: data
      containers:
        - name: zookeeper
          image: bitnami/zookeeper:3.8.2
          command:
            - bash
            - '-ec'
              HOSTNAME="$(hostname -s)"
              if [[ $HOSTNAME =~ (.*)-([0-9]+)$ ]]; then
                ORD=${BASH_REMATCH[2]}
                export ZOO_SERVER_ID="$((ORD + 1 ))"
              else
                echo "Failed to get index from hostname $HOST"
                exit 1
              fi
              exec /entrypoint.sh /run.sh
          resources:
            limits:
              cpu: 1
              memory: 2Gi
            requests:
              cpu: 50m
              memory: 500Mi
          env:
            - name: ZOO_ENABLE_AUTH
              value: "no"
            - name: ALLOW_ANONYMOUS_LOGIN
              value: "yes"
            - name: ZOO_SERVERS
              value: >
                zookeeper-0.zk-hs.default.svc.cluster.local:2888:3888
                zookeeper-1.zk-hs.default.svc.cluster.local:2888:3888
                zookeeper-2.zk-hs.default.svc.cluster.local:2888:3888
          ports:
            - name: client
              containerPort: 2181
            - name: follower
              containerPort: 2888
            - name: election
              containerPort: 3888
          livenessProbe:
            tcpSocket:
              port: client
            failureThreshold: 6
            initialDelaySeconds: 30
            periodSeconds: 10
            successThreshold: 1
            timeoutSeconds: 5
          readinessProbe:
            tcpSocket:
              port: client
            failureThreshold: 6
            initialDelaySeconds: 5
            periodSeconds: 10
            successThreshold: 1
            timeoutSeconds: 5
          volumeMounts:
            - name: data
  volumeClaimTemplates:
    - metadata:
      spec:
        accessModes: [ "ReadWriteOnce" ]
        storageClassName: "longhorn"
        resources:
          requests:
            storage: 2Gi
集群验证
1
2
3
4
5
6
7
8
9
10
11
12
# 检查FQDN
for i in 0 1 2; do kubectl exec zookeeper-$i -- hostname -f; done
# 检查生成的myid文件
for i in 0 1 2; do echo "myid zookeeper-$i";kubectl exec zookeeper-$i -- cat /bitnami/zookeeper/data/myid; done
# 检查自动生成的配置文件
kubectl exec -it zookeeper-0 --  cat /opt/bitnami/zookeeper/conf/zoo.cfg | grep -vE "^#|^$"
# 检查集群状态
for i in 0 1 2; do echo -e "# myid zookeeper-$i \n";kubectl exec zookeeper-$i -- opt/bitnami/zookeeper/bin/zkServer.sh status;echo -e "\n"; done
数据验证
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
kubectl run --rm -it zookeeper-client --image=zookeeper:3.8.2 -- bash
cd /apache-zookeeper-3.8.2-bin/bin
# 连上 zookeeper 第一个节点
./zkCli.sh -server zookeeper-0.zk-hs.default.svc.cluster.local:2181
# 创建测试数据
[zk: zookeeper-0.zk-hs.default.svc.cluster.local:2181(CONNECTED) 0] create /test test-data
Created /test
# 读取测试数据
[zk: zookeeper-0.zk-hs.default.svc.cluster.local:2181(CONNECTED) 1] get /test
test-data
# 连上 zookeeper 第二个节点
./zkCli.sh -server zookeeper-1.zk-hs.default.svc.cluster.local:2181
# 获取数据
[zk: zookeeper-1.zk-hs.default.svc.cluster.local:2181(CONNECTED) 0] get /test
test-data
GMT+8, 2025-3-11 03:25 , Processed in 1.442942 second(s), 29 queries .
