查看: 10|回复: 0
对象池框架 commons pool2 原理与实践
查看: 10|回复: 0
查看: 10|回复: 0
353
wmz
353
2025-2-5 18:29:45 | 显示全部楼层 |阅读模式
当资源对象的创建/销毁比较耗时的场景下,可以通过"池化"技术,达到资源的复用,以此来减少系统的开销、增大系统吞吐量,比如数据库连接池、线程池、Redis 连接池等都是使用的该方式。
Apache Commons Pool 提供了通用对象池的实现,用于管理和复用对象,以提高系统的性能和资源利用率。
1 基础用法
1.1 添加依赖
<dependency>    <groupId>org.apache.commons</groupId>    <artifactId>commons-pool2</artifactId>    <version>2.0</version></dependency>1.2 定义对象工厂
PooledObjectFactory 是一个池化对象工厂接口,定义了生成对象、激活对象、钝化对象、销毁对象的方法,如下:
public interface PooledObjectFactory<T> {  /**   * Creates an instance that can be served by the pool and wrap it in a   */  PooledObject<T> makeObject() throws Exception;  /**   * Destroys an instance no longer needed by the pool   */  void destroyObject(PooledObject<T> p) throws Exception;  /**   * Ensures that the instance is safe to be returned by the pool   */  boolean validateObject(PooledObject<T> p);  /**   * Reinitializes an instance to be returned by the pool   */  void activateObject(PooledObject<T> p) throws Exception;    /**   * Uninitializes an instance to be returned to the idle object pool   */  void passivateObject(PooledObject<T> p) throws Exception;}以下是一个简单的示例:
  • 定义需要池化的对象 MyObject
public class MyObject {    private String uid = UUID.randomUUID().toString();    private volatile boolean valid = true;    public void initialize() {        System.out.println("初始化对象" + uid);        valid = true;    }    public void destroy() {        System.out.println("销毁对象" + uid);        valid = false;    }    public boolean isValid() {        return valid;    }    public String getUid() {        return uid;    }}
  • 定义对象工厂
public class MyObjectFactory implements PooledObjectFactory<MyObject> {    @Override    public PooledObject<MyObject> makeObject() throws Exception {        // 创建一个新对象        MyObject object = new MyObject();        // 初始化对象        object.initialize();        return new DefaultPooledObject<>(object);    }    @Override    public void destroyObject(PooledObject<MyObject> p) throws Exception {        // 销毁对象        p.getObject().destroy();    }    @Override    public boolean validateObject(PooledObject<MyObject> p) {        return p.getObject().isValid();    }    @Override    public void activateObject(PooledObject<MyObject> p) throws Exception {    }    @Override    public void passivateObject(PooledObject<MyObject> p) throws Exception {    }}1.3 配置对象池
创建 GenericObjectPool 对象,并设置相关参数,如最大对象数量、最小空闲对象数量等。
GenericObjectPoolConfig config = new GenericObjectPoolConfig();config.setMaxTotal(20);config.setMaxIdle(5);config.setTestWhileIdle(true);config.setMinEvictableIdleTimeMillis(60000L);GenericObjectPool<MyObject> pool = new GenericObjectPool<>(new MyObjectFactory(), config);1.4 借用和归还对象
MyObject myObject = null;try {    myObject = pool.borrowObject();    System.out.println("get对象" + myObject.getUid() +  " thread:" + Thread.*currentThread*().getName());} catch (Exception e) {    e.printStackTrace();} finally {    try {        if (myObject != null) {            pool.returnObject(myObject);        }    } catch (Exception e) {        e.printStackTrace();    }}2 Jedis 连接池
Jedis 是一个 Java 语言的 Redis 客户端库。它提供了一组易于使用的 API,可以用来连接和操作 Redis 数据库。
它的内部使用 Commons Pool 来管理 Redis 连接 ,我们使用 jedis 3.3.0 版本写一个简单的示例。
public class JedisMain {    public static void main(String[] args) throws Exception{        // 创建连接池配置        JedisPoolConfig config = new JedisPoolConfig();        config.setMaxTotal(100);        config.setMaxIdle(20);        // 创建连接池        JedisPool pool = new JedisPool(config, "localhost", 6379);        // 获取连接        Jedis jedis = pool.getResource();        jedis.set("hello" , "张勇");        // 使用连接        String value = jedis.get("hello");        System.out.println(value);        // 归还连接        jedis.close();        // 关闭连接池        // pool.close();        Thread.sleep(5000);    }}如下图,JedisFactory 实现了对象工厂,实现了创建对象销毁对象验证对象激活对象四个方法。
比如验证对象方法,逻辑是调用 Jedis 的 ping 方法,判断该连接是否存活。
3 原理解析
我们重点解析 GenericObjectPool 类的原理。
3.1 初始化
public GenericObjectPool(            final PooledObjectFactory<T> factory,            final GenericObjectPoolConfig<T> config) {     super(config, ONAME_BASE, config.getJmxNamePrefix());     if (factory == null) {          jmxUnregister(); // tidy up          throw new IllegalArgumentException("factory may not be null");     }     this.factory = factory;     idleObjects = new LinkedBlockingDeque<>(config.getFairness());     setConfig(config); } private final Map<IdentityWrapper<T>, PooledObject<T>> allObjects =        new ConcurrentHashMap<>();初始化做三件事情:
  • 初始化 JedisFactory 工厂对象。
  • 对象容器 idleObjects , 类型是 LinkedBlockingDeque
    因此存储容器有两个,所有的对象 allObjects 和空闲对象 idleObjects (可以直接取出使用)。
  • 配置对象池属性 。
3.2 创建对象
我们关注 GenericObjectPool 类的 borrowObject 方法。
逻辑其实很简单 :
  • 从容器中获取第一个条目对象,若没有获取,则调用工厂对象的创建对象方法,并将该对象加入到全局对象 Map。
  • 创建成功后,调用对象的激活方法,接着验证对象的可靠性,最后将对象返回。
3.3 归还连接
流程如下:
  • 判断返还对象时是否校验,假如校验失败,则销毁该对象,将该对象从存储容器中删除 ;
  • 调用工厂对象的激活对象方法 ;
  • 若空闲对象 Map 元素大小达到最大值,则销毁该对象,将该对象从存储容器中删除 ;
  • 正常将对象放回到空闲对象容器 idleObjects
<hr>
参考资料:
https://github.com/redis/jedis/wiki/Getting-started
https://github.com/apache/commons-pool
GMT+8, 2025-3-10 15:13 , Processed in 0.898288 second(s), 30 queries .
